Ok, so my assumption was always that the 12v power in your 7-pin provided a little charge to your camper battery.
On my last trip I noticed in my Victron SmartShunt app that my trailer battery was pushing power to my TV (roughly 100 watts or so). So it was doing the exact opposite. I get that the power can run both ways but what causes the camper battery to push power to your TV…or am I reading the Victron app incorrectly?
I have the two 6v AGM Harris batteries.
2020 Tacoma TRD Off-Road
Some assumptions:
-- Tow Vehicle real-world 7-pin can source 3'ish amps. "The trickle charge"
-- Solar Panel might provide another 3'ish amps.
-- TaB has a background current demand of 1 Amp or less. Things we can not turn off.
-- Newer DCV compressor fridge draw ~9A when compressor is on
-- The Victron Shunt is reporting Amps in/out of battery.
So:
Is the Shunt 'current out' due to Fridge draw what is really happening?
Note that you can't really add up the charging amps from multiple chargers. The charger with the least resistance will be the primary charger. The other charger (alternator) will see the higher voltage from the other charger and think the battery is fully charged and not charge.
