I have the lithium package and am getting ready to return to the dealer 2nd time for Victron problems. My batteries read 90% and yet the low battery light flashes and and the Victron will not distribute any power. First time back I was told the Victron’s were coming from the factory programmed incorrectly and I was their 2nd unit with this issue.They reprogrammed and same problem is back. I’m told this is Victrons first foray into the camper market.
Has anyone else been down this road and we’re they able to fix?
The programming of the Victron is actually pretty straightforward, so someone at either NuCamp or Battleborn is not paying attention when these get programmed. The Multiplus cannot be programmed using the Victron Connect App on a phone or mobile device. You need the VE Bus Quick Configure program that only works on Windows.
Since I did my own install on my '23 Tab 400 I also purchased the Victron MK3-USB interface in order to program the unit. Battleborn supplied me with the programming instructions and I was able to setup it up successfully without any issues. Hopefully, Victron will update their Multiplus units so that it is easier to program the units.
I made that change and used the other Connect settings that were recommended on here and noticed the State of Charge was showing 100% even though the voltage was well below what should be a 100% charge.
Is there any way to check the rest of the programming without an MK3-USB interface? If not, I'll go ahead and pick one up and download the configuration software. Are you able to share the programming instructions that you used?
Thanks!
I am able to get to these parameters using the Victron Connect app over bluetooth to the VE.Bus - is there something else that requires the USB interface?
