At our last camping at Laurel Hill state park, I turned the Alde off before disconnecting the electric using the control panel. We drove to the cabin and parked it in the garage. Turned the battery switch off and turned the breaker off for the garage when we left.
Arrived today, and while working in the garage I heard a sound that sounded like a distant fire alarm starting to ramp up. Happened a couple of times until I thought that sounds like the Alde circulator.
Went inside and turned the Alde control panel on. (Screen was dark) No electric elements were turned on and no gas was turned on. The thermostat was set at 66 and the thermometer on the kitchen table said 66. I started turning the thermostat down and when I got to 64 the circulator turned off. I ran it down into the 50’s to be sure.
How could the circulator run with the control panel turned off? 2016 320 CS S. Any thoughts?
Golden, CO
Golden, CO
Apparently with our Alde 3010 if the thermostat is set high enough the circulator will run even though no electric elements or propane is chosen and the Alde is turned off. Makes me wonder about last winter. I kept the garage at home at 38 degrees and the T@B was plugged in all winter.
= - Before turning the Alde Control Panel Power 'off' I always manually turn off the electric or propane
= - heat source. When the Alde Control Panel is turned back on the circulation pump will be on if the
= - cabin temperature is below the Control Panel temperature set-point. Owners manual: "the pump
= - for circulating the glycol heating fluid start automatically whenever heat is called for by the thermostat".
There is nothing in the User manual about 'holding Control Panel on/off Switch for an extended time' to cause a special operation { reset or hard power off }
My experience with the Control Panel has been the opposite . . . if the Off Button is pressed too long the Adle gets confused - - - seems to jump back on. Both that's just one users experience.
