In-line water pressure regulator?
WildRumpus
Member Posts: 46
I just watched a Mandy Lea YouTube video about 2022 NuCamp updates (because I own a 2022 and was curious). She mentions that the 2022 Tab 400s have inline water pressure regulators. Is that true? I’ve been using my own regulator but if it’s not necessary then why bother?
Gainesville, FL
_____________________________
2016 CSS 320
2022 Tab 400 Boondock
2021 BMW X5 45e Plug In Hybrid
2016 CSS 320
It was true, then suddenly was not true. We aren't exactly sure, but either NuCamp couldn't obtain any "FloJets" due to pandemic supply issues. Or...they didn't work. Opinions differ!What was happening to owners with the "Flojets" was the Yellow Flapper Valve was leaking.This is one thread that shows what to look for, and the various comments with owners comparing build dates.Here is a recent thread that talks about the "FloJet" causing the Alde flapper to open.
Towed by 2014 Touareg TDi1 -
Thanks pthomas! I genuinely tried a search before I posted but was inundated with pages and pages of results that tended to be about propane regulators.So it appears (from that thread in March 2022) that NuCamp did indeed stop installing them on the 2022s fairly early on. Mine was built in Aug 2022, and I’ve been using the external pressure regulator with no problem so I shall continue to do so.Gainesville, FL
2016 CSS 320
3
