Tap into DC power under kitchen sink?
I want to install an Acuva UV water treatment system under the kitchen sink in my 2023 T@b 400 BD. Can I tap into any of the wires there for DC power? The system draws ~9W when active (while water is running) and ~0.1W when not active.
2023 T@b 400 BD (Serenity) | 2024 Chevy Colorado Z71
  • dragonsdofly
    @Stokes400Boondock that is a very interesting question and the first time that I know of something like that even being considered.
    T@b forum wizards, have at it. I'm going to enjoy this upcoming discussion!
    Good luck @Stokes400Boondock.
  • Maxcamp
    Maxcamp Member Posts: 352
    Our 2021 320 has 12v usb power outlet under the sink, wires come in from behind bath sink and are part of a two outlet dedicated circuit.  If you need 12v fractional amperage this might be a good source to tap.
    In contrast, Piggybacking on fridge fuse might overload that circuit.
  • manyman297
    manyman297 Member Posts: 1,434
    I’m not sure if the 2023 is different but the 2021 has the fuse box right next to the under sink cabinet. It would be fairly easy to run a dedicated fuse and outlet for it.
    2021 400 BD
    2020 Tacoma TRD Off-Road
