Hi this is Bob and my wife and I have a 2018 TAB 400 we bought new.  We have never camped in the cold before, so we have never had a need for the heater. I do not know if I am just doing it wrong or what.  My Alde water heater works fine.  I checked the 2 fuses on the Alde unit itself and they are fine.  I set the temp on the Alde control panel and nothing happened so I went to the Dometic control and put it on Heat/Furnace and set the temp the same as the Alde.  The blower comes on but all it blows is cold air.   The temp outside the trailer is in the mid 50's if that helps. I also have a full propane tank that is turned on.
Please help me and tell me what I'm doing wrong. Bob
                Bob & Irene  2003 F150 V6-Manual
2018 TAB 400
Nashville, TN.
0 ·
The set temp on the panel may be several degrees off the actual air temp near the bed, so be aware of that.
More on that depending on your results with these first checks.
Good luck and read the Alde manual for control panel details.
ps the Dometic CoolCat system is separate from Alde and one should not influence the other when the trailer is cold
As mentioned above the Coolcat is a separate system so let's put that aside. The water heater is the outer layer in the boiler with the glycol being what is actually heated so there is at least some glycol in the system. I'd check at the Alde system itself if the heater hoses get warm and if the circulation pump is running. Both are easily done by putting a hand on it. Then double check all the settings in the control panel, hot water and heat, crank up the target temp etc..
I will let you know what I discover
2018 TAB 400
Nashville, TN.
2018 TAB 400
Nashville, TN.
If the bed area is not warming, you probably have something blocking the air intake under the bed or the air vent above the shelf. This system is dependent on the natural movement of the air. Anything blocking vents will effectively turn off that convector.
If the temperature you set is very different than the cabin temperature, you can adjust the thermostat setting number from the services menu.
The guides on the Alde website are very good. They are well written for normal people, not the google translation or computer speak one often finds these days. They contain both clear instructions and techniques for use.
"Just Enough"
