My AGM batteries seem to be on their way out, and replacing with lithium seems to be a no-brainer. Having already established that AGM batteries can probably be discharged by 80% without loss of overall life (see previous post
https://tab-rv.vanillacommunity.com/discussion/9940/agm-battery-depth-of-discharge-myth-busted/p1) and having got the impression that lithium batteries were so much better, I was a little surprised to see this in the specifications for LiTime 460Ah LiFePO4 batteries:
Cycle Life: 4000 cycles at 100% DOD, 6000 cycles at 80% DOD, 15,000 cycles at 60% DOD
While readily admitting that even 4000 discharge cycles of a Lithium battery beats out AGM batteries (and mine never made it that far), I am shocked to see that discharging to 60% will more than double the total Ah delivered by this cell in its lifetime. Is this the dirty secret of LiFePO4 batteries? They may have more cycles than you will ever need, but are they much more compromised by deep depth of discharge than AGMs?
Virginia Beach, VA
At the end of the day, with LiFePo4 batteries, you are gonna install them and enjoy getting into the great outdoors.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
The above 200ah lifepo4 battery pack weighs 38 lbs. and fits inside a small Group 24 battery box. To get anywhere near the equivalent performance (and cycle life) from lead-cell or AGM batteries would require at least 200 lbs. of lead . . . 4 times the space . . . and the purchase of 5 replacement sets of lead-cell/AGM batteries.
The difference in performance between lifepo4 and lead-cell chemistry is huge, almost laughable.
There are at least two others reporting similar Harris battery failures from that same generation on this forum.
Seems we got some duds...
I'll be installing a Li Time 460ah this week, and hopefully never have to think about it again!
"Just Enough"
