I am interested in the new SOK 280ah battery to replace the two AGM I currently have, which aren't holding a charge so well. I have two questions here:
Is it a simple swap with the 2021 tab320 BD? I read that shore power will have trouble charging to 100% but solar can top it off. Will that be true in my case?
Second, I am reading that people are relocating lithium batteries inside. Is there a reason for this other than storage/weight distribution? Does anything else need to be relocated if you do this?
Thank you all!
0 ·
Where is the the WFCO located? I will check that. But from the other threads I have read I am guessing I have the one that charges to 85%. This doesn't sound like a problem for my use case though.
I think I might go with this less featured battery. Still well-reviewed by Will Prowse and half the price. I don't need all the Bluetooth bells and whistles of the other, but I'd be missing out on the heating pad: https://www.litime.com/products/litime-12v-230ah-plus-lifepo4-battery-built-in-200a-bms-max-2944wh-energy
That said I am not in a cold climate anyway.
Also after perusing the threads you linked about moving the batteries inside, that helped a lot. It does not seem like something I am particularly interested in as theft seems like the most compelling reason, but I don't ever really leave my trailer where this would be an issue. Of course, who knows, but it seems like there are easier antitheft measures.
I definitely don't need the pad right now. I am not camping anywhere where temps are freezing throughout the day, so it seems like the cheaper battery would be fine for me. And I could insulare if it were an issue, but I doubt it will be.
Thanks for the good questions to follow up on @pthomas745
I have a '21 320 and moved my batteries inside for the sole reason of increasing storage in the front tub. I had two lead acid batteries inside the front tub which took up a lot of space and opening that space for items has been a big storage advantage for me. I placed two lithium batteries inside next to the Air 8 as that space had very limited access and use for me. We go on multi month trips and the change in space allocation (more space in the front tub) has been big for me.
If you put them inside (either by the Air 8 or side compartment), it's only a minor wire change on the inside and the installation of a new ON/OFF battery switch to hook them up without the need to cut any holes in the TAB. If your interested, I'm happy to send you a wire diagram of how to do it.
Because of the lightness in lithium batteries, IMO, the weight issue is not a factor. I just can't see how 40 lbs or so (with proper tongue weight) makes a difference of where they placed inside or out.
My experience with the my WFCO lead acid battery charger is it will charge the two lithium batteries past 85% and all the way to 100%, but extremly slow. I'm in the process of installing a victron lithium charger to help with that.
We do travel/camp in the cold shoulder seasons. I have not considered any type of heater because the battery BMS (if equipped) prevents any cold weather charging from solar. I also will turn off the solar charging via the app. as an extra safe guard when in cold weather. If camping/traveling in cold weather and on shore power, the batteries are now inside, warm and can be charged.
Southern Maryland
2017 F-150
Coeur d'Alene, Idaho
Also do you turn off solar charging with the standard victron app?
@WayneW is the Victron Battery Sense to automate that process? I will have to look that up because I am unfamiliar with it.
2017 F-150
You still have to get power to the electric e brakes. also did a slight modification to put power to the e brakes independent of battery switch so in the unlikely event the battery switch is off, the e brakes always have power. If it’s still fuzzy, it will be clear when I send the diagram.
Southern Maryland
Here is a method to bring batteries inside and wire them without cutting any holes in your TAB. The top shows how the battery is wired if it's in the front tub and below shows how to wire if you bring it inside.
You would cut the #6 wire behind the WFCO. This is the same wire that exits from inside , goes outside through a penetration to the trailer junction box and to the battery in the tub.
You would take the cut wire from the WFCO side and wire (10 AWG) it to a new switch. I placed a new switch to the rightof the WFCO panel. But you can put it any where. From the switch , you go to the a new positive bus bar. The bus bar has connections to the new battery inside and to the other cut end of the #6 wire that goes outside to the junction box. This way , the junction box always has power , where the emergency brakes are also wired to and thus always are powered independant of a ON/OFF switch. There may be a reason to remove power from the e-brakes, maybe for maintenance, but you could just remove the wire from the bus bar. You could skip the busbar and wire the brake directly to the battery, but it's always a good practice to minimize connectionsto a battery.
I'm not sure it's necessary, but I also put a fuse (not shown) between the busbar and the wire going out to the junction box. I also put a very small (pencil point size) LED light downstream of the fuse, so I can see if the fuse should blow, the light would be out. The light shows me, at a quick glance. that the e-brakes have power.
Hope this helps.
Southern Maryland
Rather than a bus bar, would it be possible to use a terminal block in this application? Something like this? https://www.mcmaster.com/products/terminal-blocks/terminal-blocks-11/
And do you need to put a ground in the interior?
The two things to consider when sizing wire is how much current it will carry and the distance run (both ways). Do you (or plan to) have an inverter? If so, that will impact the size? If you do not have an inverter, you can go with smaller AWG wire. If you do not have an inverter, your TAB max. current capacity is probably only 30 amps and you can size your wire for that current. If you have an inverter, the first thing to do is size your fuse based on the wattage of your inverter, then size your wire based on the fuse size and distance run.
So, while bigger never hurts, it may not be necessary.
Here's a link to help.
Circuit Wizard - Blue Sea Systems
Keep asking and good luck with your project...
Southern Maryland
I'm not an expert in this but busbars and terminal blocks serve different purposes. Terminal blocks are used to connect an incoming and outgoing wire while bus bars are used to connect wires to distribute wires to different circuits. So which to use depends what you want to do with your wiring..if that makes sense.
Not sure what you mean by ground in the interior? If you mean when moving your batteries inside , I wired the negative leg to the negative bus bar behind the WFCO.
Southern Maryland
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
I also read something about the flow of electrons being a reason for connecting to opposite batteries, but can't find an explanation that I can understand. Maybe someone can clarify if that's a consideration?
Is there another page to that diagram that describes why you would select one way over another? If they are all "correct" there must be a reason one would choose one way over another? i.e cost of components? what you have on hand ? or just how you feel that day
Southern Maryland
2025 Ford Ranger
I have seen that other people like to put it next to the AC unit, but there is plenty of space here and I'll even have some storage left over. I'll just have to run a couple of wires around to the WFCO/ground, but that looks easy, as there is pre-existing space to run wires through for the most part.
I think I'm going to order my parts from McMaster Carr. Am I leaving anything out? Going to list parts and prices, in case anyone comes back to this thread in the future wanting to do something similar.
Distribution Bar ($27): https://www.mcmaster.com/catalog/129/855/9290T12
Mini Rocker Switch ($5): https://www.mcmaster.com/catalog/129/1085/7395K28
LED ($5): https://www.mcmaster.com/products/led-lights/panel-lights-with-quick-disconnect-terminals-7/
Fuse block ($5): https://www.mcmaster.com/products/fuse-blocks/
10 ft black 6gauge battery wire ($23): https://www.mcmaster.com/products/wire/electrical-wire~/american-wire-gauge-awg~6/
10 ft red 6gauge battery wire ($23): https://www.mcmaster.com/products/wire/electrical-wire~/american-wire-gauge-awg~6/
Questions I'm left with:
I believe the wiring in there now is 6 gauge. Is that sufficient for this application? I see people suggesting 2/0 in this thread, but it looks like that is for putting batteries in parallel. Happy to increase the gauge if necessary though.
What size fuse did you put in there? I put in a fuse block that holds a 30amp auto fuse, given that the tab accepts a 30amp connection.
2/0 AWG is not necessary for what you are doing. Folks are using that size wire when installing an inverter. 10 AWG is fine for a 30 amp circuit if you are moving a single battery inside, If your wire length is a bit longer you can use bigger wire such as the 6 AWG. You are tying it into 10 AWG of the WFCO.
Curious on a few things.
-What is is the mini rocker switch for?
Will it act as a battery switch? If so, make sure you get one that meets the amp rating (30 A ) of your circuit. A little bigger again never hurts.
-What is the LED for?
Not shown in the bottom of the diagram I posted are two things. One is a very small LED light that I surface mounted in the board between the air conditioning outlet and the lagun table leg mount; the second is a 30 amp fuse. These are spliced into the wire that goes between the positive bus bar out to the trailer junction box. The purpose of the light is for at a glance I can see that I have power going out to the trailer junction box and the fuse serves to protect that circuit and allows me to remove power to the trailer emergency DC brakes if they inadvertently activate or for maintenance.
-What type of fuse block are you getting? Again, make sure you get one rated for 12V/30 amps.
Other things you may need are wire butt conectors and crimper.
Are you making a drawing? Always good to have one and leave in a plastic sleeve nearby to remember your wiring changes or for others to trouble shoot. I also marked my wires with numbers and names to help with trouble shooting. Use small labels around the wires.
The pdf posted by @elbolillo is a great resource to look at.
Southern Maryland
