Anyone using a Renogy inverter/charger in their TAB?
Hammick
Member Posts: 80
(Spelling corrected for search purposes. Moderator)
Has anyone gone the Renogy route? They also make the inverter/charger without Bluetooth for approx. $110 less.
I've read some bad stuff about Renogy customer service but I would buy from Amazon and put the Renogy through a bunch of testing before installing it in the trailer. If it has problems I could return to Amazon within 30 days.
I'll probably check over at the big RV forums but wanted to see if anyone with a TAB was doing it.
Seems like more than a few have installed them over the years.
Hi,
Here are a couple of other forums (if your not familar) I follow for RV installs that you may be able to find info.
Vehicle Mounted Systems | DIY Solar Power Forum (diysolarforum.com)
Beginners Corner | DIY Solar Power Forum (diysolarforum.com)
I also read over and over about Renogy's bad customer service and not so stellar quality control. I don't have an inverter/charger, but just a Renogy 2000W inverter and have had no issues.2025 360 CS
Southern Maryland0
- 143 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 918 Tips & Tricks
