Tab table downsize
BywaysNW
Member Posts: 71
OEM table is heavy and awkward to get around. Replaced with cutting board, groove-side down.
Ha. the previous owner of our 320 made an even bigger tabletop that friction slips over the stock one.
We haven’t found a reason to use it yet.Jeremy | '22 320S | 4Runner | Peoria, IL -
I am keeping the original handy to put on top of little one when we need the space. Will have a look at the friction slip solution to keep it from sliding off.
Hi,
Very nice...another option to down size for the area is to make a drop leaf. We keep the OEM table outside full time.
2025 360 CS
Southern Maryland -
Home Depot sells an inexpensive, but nice, piece of wood for tool box tops. We replaced our 400 table with one.
https://www.homedepot.com/p/Husky-26-in-Hardwood-Tool-Cabinet-Top-for-Rolling-Cabinet-HOCN260001/203949843
Rich2019 T@b 400
Good suggestions. Thanks!
We use the factory table (2021 320S) but I shifted the mounting and drilled/screwed 2 new holes. It requires more turning in some cases but allows the table to be closer to the rear seat backs or much more available to the cook when additional space is needed. We found it a good way to get a smaller and bigger one using the same top.Snohomish WA, 2015 Diesel Grand Cherokee
managed by VE Smart Network -
I made the bracket slide on the original table bottom. This allows infinite adjustability and was easily accomplished by fabricating a couple slide tracks. In my case some oak molding scraps with a saw slot got the job done. They're even held in place with the original bracket's screws and I stained them to match the UT's cabinets. There are central rubber bumpers to stop the bracket from traveling too far and the black thumb screw locks it in position.
NIce bracket solution. I'm going to try that.
- 916 Introductions
- 73 Teardrop Groups & Links
