Tongue and total weight of 2024 T@B 400 w/ bunk
floridamanfloridaman Member Posts: 20
Hello all, wanted to share that I just took my 2024 T@B 400 w/ bunk to the scales. Note that our fresh tanks are about 1/3 full and some light essentials on board (less than 25 pounds of stuff).
Tongue weight: 420 pounds
Total weight: 3060 lbs.
Hopefully this can help someone.
2024 T@B 400 Boondock
    @floridaman thanks for the info. Adds to all of our collective knowledge.
    Thanks for the info.  Always good to hear about real world weights.  Depending on how I have our 2021 400 loaded our tongue weight, using etrailer tongue weight scale, will be between 380-400lbs.  My last Cat scale weight of our our trailer, loaded with food and normal camping gear, no water was 3120lbs.
    2021 T@b 400 BD  "Vixen Gail"
  • phan2014phan2014 Member Posts: 1
    Thanks for the info. Was your propane tank full or empty? The specs says 2024 Tab 400 Boondock with Bunk is about 430lbs tongue weight dry. Water in the fresh tank seems to reduce the tongue weight a bit.
