Pahaque Cover for 2024 320 S- Too tight??
Has anyone else had trouble fitting a Pahaque cover on a newer model Tab 320?  It's super tight, especially when pulled over the front tongue storage box (feels like it will tear).  It's tight enough that I'm worried about the zippers tearing long term (hard to close it), even without the storage box included.  I've asked Pahaque and they say this is how it's supposed to be, and that this cover IS NOT supposed to cover the front storage box (even though all the pictures on their website and elsewhere show it covering that box-- which is one of the reasons I bought it).  I have the cover stuffed in behind the storage box bunched up on the propane hoses currently.  Anyone else have pictures of their newer 320 with a Pahaque cover or have similar fit issues?
  • kevmonkevmon Member Posts: 34
    Is this the cover they make for the 320 S or Boondock? I just got the larger boondock one and it goes over tub.
    2023 T@B 320
  • EasternJLEasternJL Member Posts: 105
    Its for the Boonedock model.  I ordered the wrong one to start with and sent it back and got the Boonedock model.  Does yours fit tight like you see in the picture? (and tighter, obviously, with the tub covered?)
    Also, does your 320 have the cage in the back.  I'm not sure when that started becoming standard, so I thought I'd ask.  Without that cage, it would certainly fit correctly.
    No cage on back of mine. That’s probably the difference
    2023 T@B 320
    @kevmon Yep-- yours fits great (including the front box of course).  Comparing your picture to mine, it's clear that the rear cage is the difference.  Nucamp lists the cage as standard equipment (except for the CS of course), and all models are Boondock now--- so I'm assuming all 320 S models would have the cage.  Though I could be wrong about that.
    I'll reach out to Pahaque again.
    Thanks very much for chiming in and providing the pictures!
