Paint laminate cabinets?
lkc001
Member Posts: 881
Has anyone attempted to paint the laminate cabinets on a 2018-2019 Tab 400?
2018 Tab 400
Use a good etching primer and sand before you paint. Nothing different than doing this in a house. I will be repainting the painted white cabinet doors under the sink. the very cheap materials/paint used stains and can't be cleaned.Full-time rving since 2006, tab owner since 20220
So sand with like a 180 grit then etching primer then paint? Would you use a sealer also? The color on the upper cabinets is just so ugly, IMHO.Citruscountytab400 said:Use a good etching primer and sand before you paint. Nothing different than doing this in a house. I will be repainting the painted white cabinet doors under the sink. the very cheap materials/paint used stains and can't be cleaned.2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab0
