Over head fan died
Ruth1098
Member Posts: 3
My overhead fan in my 2018 320s is suddenly not working at all. Check for fuse issues, but fuses are okay.
Anything else that might be a problem to check before I replace it?
On the Fantastic fan itself, there is a fuse on the unit. Have you found that one? Look at the Fuses thread below, and look at that little fuse in the holder. (If you haven't already!)If this fuse is ok, there might be ways to check if the power switch, etc, is still functioning.
Towed by 2014 Touareg TDi1 -
Thanks for the reference. Did check the fan fuse first. Seems to be intact.0
The Roof Fan has an internal fuse [already noted in other comments] and three switches that control power.
1} 3-Speed Power
2} Air Flow Direction, center is off
3} Lid Open, lid must be open a couple of inches
Confirm all switches are in the operate mode.
My fan was working intermittently and appears to have been caused by a stuck lid closed switch. Just FYI for anyone else having a similar issue.2021 400 Boondock / Jax, FL
2018 320-S1
