Over head fan died
My overhead fan in my 2018 320s is suddenly not working at all. Check for fuse issues, but fuses are okay.
Anything else that might be a problem to check before I replace it?
    edited July 2024
    On the Fantastic fan itself, there is a fuse on the unit.  Have you found that one?  Look at the Fuses thread below, and look at that little fuse in the holder.   (If you haven't already!)
    If this fuse is ok, there might be ways to check if the power switch, etc, is still functioning.
  • Ruth1098
    Ruth1098 Member Posts: 3
    Thanks for the reference. Did check the fan fuse first. Seems to be intact.
    MuttonChops Member Posts: 2,087
    The Roof Fan has an internal fuse [already noted in other comments] and three switches that control power.
      1}  3-Speed Power
      2}  Air Flow Direction, center is off
      3}  Lid Open, lid must be open a couple of inches
    Confirm all switches are in the operate mode.
  • psuvtech
    psuvtech Member Posts: 11
    Hello @Ruth1098 did you ever solve this problem?  Our stock fan in our 2018 320 S just stopped working as well and fuses seem fine.
    Thanks!
    2021 400 Boondock / Jax, FL
    2018 320-S
  • psuvtech
    My fan was working intermittently and appears to have been caused by a stuck lid closed switch.  Just FYI for anyone else having a similar issue.
    2018 320-S
