Additional, portable solar panel
Doug_Edwards
Member Posts: 8
Hi Folks, we have a 22 400 BD with solar panel. I'm wondering about the practicality of an additional 140w suitcase panel, (there is already a connection port), for shady conditions or additional power. Anyone have experience or advice?
Doug
2022 400 Boondock
2023 Tacoma TRD Sport
Western Maine
2022 400 Boondock
Western Maine
We have 8 billion solar threads! Many owners have done this. There are lots of options: solar "suitcases", standalone solar panels, lightweight "flexible" panels...and on and on.At the very least, you will need: the panel. A solar controller. And the various cables that connect the panel to the controller, and the controller to the battery. Some panels come with the controller mounted on the panel, such as a "suitcase" type. Others have each of these components as separate parts of the "kit".For you to understand the SAE port (that is what that "connector" on the side of the trailer really is) you will need a multimeter, or at least a meter is a very useful part of your Tab toolbox.There are many simple ways to connect solar to the trailer. There are many owners here with many skillsets and experience with this sort of installation. There are some (like me) who took this step by step and simply made it work first, and then improved the "look" as I went along.This thread started in 2016. There was not much information about solar and how to make it work with the trailers, since the solar geeks simply did not see what was coming down the road. So, smart owners figured it out. The thread was "resurrected" early this year, with examples of the newer style "suitcase" type panels.Many owners have discovered the ease of use of these Dokio kits, which appear to be plug and play.Anyway: it isn't as hard as it looks to make it work. Ask questions, there is so much expertise here.
Towed by 2014 Touareg TDi1 -
Thanks, I found a bunch more info. I'm fairly handy at things but very literal. Vague or ambiguous don't work for me. If it doesn't hit me over the head, I'm afraid I'm missing something. Turns out, someone with the same setup has done what I want to do, and it's plug and play. Always great info from other owners.Doug
2022 400 Boondock
Western Maine2 -
Our 2023 T@b 400 does not have external port for adding a “solar suitcase”. It looks like this port is usually in the nautilus panel. Has anyone DIY a port? Or is this something a dealer should do?0
You can add a port without too much effort. I added a Zamp connector to the front tub and run to a second solar controller.redaunt said:Our 2023 T@b 400 does not have external port for adding a “solar suitcase”. It looks like this port is usually in the nautilus panel. Has anyone DIY a port? Or is this something a dealer should do?2023 T@B 320
2021 Jeep Grand Cherokee0 -
I installed an additional solar charger and a MC4 connector in the nautilus cubby.
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia2 -
elbolillo said:I installed an additional solar charger and a MC4 connector in the nautilus cubby.
Wow! I didn't know they made a quick connect MC4 plug. I thought you had to use the tool to disconnect them. Where did you get that plug?2021 T@B 400 BDL aka Little Joe
2019 Tundra Crewmax aka Hoss
SE Louisiana0 -
I installed a solar controller in the tub (Victron), an SAE port on the side, and I have a 160w EcoFlow portable panel.Doug_Edwards said:Hi Folks, we have a 22 400 BD with solar panel. I'm wondering about the practicality of and additional 140w suitcase panel, (there is already a connection port), for shady conditions or additional power. Anyone have experience or advice?San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
Here is one that is available on Amazon https://www.amazon.com/Weatherproof-Housing-Extension-Connector-Campervan/dp/B0B6GD2J5D/ref=sr_1_4?dib=eyJ2IjoiMSJ9.qa0cCwzxL0QpvZyK8PmyGLqQb1JFIBoMMU7BlDeGNj504tqw0QPojQSzTYt6Rxi5HTLYZobqhnbC-RRYxKc8LLLFpXlBvYxGazIFfci9Wuwwlm_2Y6JlqHNWcxIhb9p6x8fLhTJlcuW6nLe2dWUErYe9QuYWttBQAXuJNaRjSjyxp2Y6Jo6Ev1OsYBhY0eByXYI2gBJYkOF7NyVQJoYVO3p_Fk5nM_jbGqAg_GquEVI.3WdfnlCtuRTcxyYr1eFAqfOejVrgZR1ge1YFcszOblI&dib_tag=se&keywords=Solar%2BPanel%2BWeatherproof%2BCable%2BWire%2BEntry%2BHousing&qid=1720633999&sr=8-4&th=1cottonmouth said:elbolillo said:I installed an additional solar charger and a MC4 connector in the nautilus cubby.
Wow! I didn't know they made a quick connect MC4 plug. I thought you had to use the tool to disconnect them. Where did you get that plug?_____________________________________________________
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia0 -
We have a 200 watt Renogy portable suitcase with a 20' extension cable. Moved the Renogy controller from the panel to inside the tub next to the SAE port so we don't get much power loss when using the extension cable.
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York1 -
We have a ‘22 400 BD. The practicality of a suitcase panel is immense. I’ve used it with my 320 and 400. We try to park in the shadiest sites. A mobile panel with good length of cord allows this while placing the panel out in the sun.2022 TAB 400 Boondock, 2019 Toyota Tacoma Sport 4x4
Odessa, Fl.
