Additional, portable solar panel
Doug_Edwards
Doug_Edwards Member Posts: 8
Hi Folks, we have a 22 400 BD with solar panel. I'm wondering about the practicality of an additional 140w suitcase panel, (there is already a connection port), for shady conditions or additional power. Anyone have experience or advice?
Doug
2022 400 Boondock
2023 Tacoma TRD Sport
Western Maine
    pthomas745 Administrator, Moderator Posts: 4,661
    We have 8 billion solar threads! Many owners have done this.  There are lots of options: solar "suitcases", standalone solar panels, lightweight "flexible" panels...and on and on.
    At the very least, you will need: the panel.  A solar controller.  And the various cables that connect the panel to the controller, and the controller to the battery.  Some panels come with the controller mounted on the panel, such as a "suitcase" type.  Others have each of these components as separate parts of the "kit".
    For you to understand the SAE port (that is what that "connector" on the side of the trailer really is) you will need a multimeter, or at least a meter is a very useful part of your Tab toolbox.
    There are many simple ways to connect solar to the trailer.  There are many owners here with many skillsets and experience with this sort of installation.  There are some (like me) who took this step by step and simply made it work first, and then improved the "look" as I went along.
    This thread started in 2016.  There was not much information about solar and how to make it work with the trailers, since the solar geeks simply did not see what was coming down the road.  So, smart owners figured it out.  The thread was "resurrected" early this year, with examples of the newer style "suitcase" type panels.
    Many owners have discovered the ease of use of these Dokio kits, which appear to be plug and play.
    Anyway: it isn't as hard as it looks to make it work.  Ask questions, there is so much expertise here.
  • Doug_Edwards
    Thanks, I found a bunch more info. I'm fairly handy at things but very literal. Vague or ambiguous don't work for me. If it doesn't hit me over the head, I'm afraid I'm missing something. Turns out, someone with the same setup has done what I want to do, and it's plug and play. Always great info from other owners.
    Doug
    2022 400 Boondock
    Western Maine
  • redaunt
    redaunt Member Posts: 31
    Our 2023 T@b 400 does not have external port for adding a “solar suitcase”. It looks like this port is usually in the nautilus panel. Has anyone DIY a port? Or is this something a dealer should do?
  • kevmon
    kevmon Member Posts: 34
    You can add a port without too much effort. I added a Zamp connector to the front tub and run to a second solar controller.
    2023 T@B 320
  • elbolillo
    elbolillo Member Posts: 575
    I installed an additional solar charger and a MC4 connector in the nautilus cubby.
  • cottonmouth
    cottonmouth Member Posts: 109
    Wow! I didn't know they made a quick connect MC4 plug. I thought you had to use the tool to disconnect them. Where did you get that plug?
    2021 T@B 400 BDL aka Little Joe
    2019 Tundra Crewmax aka Hoss
    SE Louisiana
  • Marceline
    Marceline Member Posts: 1,770
    Hi Folks, we have a 22 400 BD with solar panel. I'm wondering about the practicality of and additional 140w suitcase panel, (there is already a connection port), for shady conditions or additional power. Anyone have experience or advice?
    I installed a solar controller in the tub (Victron), an SAE port on the side, and I have a 160w EcoFlow portable panel.
  • elbolillo
  • SLJ
    SLJ Member Posts: 659
    edited July 2024
    We have a 200 watt Renogy portable suitcase with a 20' extension cable. Moved the Renogy controller from the panel to inside the tub next to the SAE port so we don't get much power loss when using the extension cable.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • Slackers
    Slackers Member Posts: 490
    We have the exact solar set-up as @SLJ I'll add the 200 watt solar suitcase is a bit bulky to move around; however, It gets the job done for our 100 AH lithium battery.
  • GatorEgg
    GatorEgg Member Posts: 482
    We have a ‘22 400 BD.  The practicality of a suitcase panel is immense.  I’ve used it with my 320 and 400.  We try to park in the shadiest sites.  A mobile panel with good length of cord allows this while placing the panel out in the sun.
    Odessa, Fl.
