Issues with TAB400 Air Conditioner
Hi-  We are new to camping.  On our most recent trip we were using the air conditioning which began leaking water from underneath the cabinet near the intake.  Upon inspsection, it was the pan under the unit that was overflowing. My thought is that we weren't perhaps level enough?  No water was coming out of the flow tube on the outside.  Any other ideas?  I don't have a manual for the AC ....is it a Dometic?  It was alot of water!!!
  • Governor
    Governor Member Posts: 14
    what year
  • subkron
    subkron Member Posts: 208
    Sounds like the drain hole/tube is clogged. Not sure what the diameter is but I would think a coat hanger or some such run up the tube would clear it. If you have water in there seems like the AC is doing it's job.
    I wouldn't overly force the rod, it may just be bugs or general schmutz blocking the drain.
    2022 T@B 400 Boondock
    South Jersey
  • rfuss928
    rfuss928 Member Posts: 1,197
    edited July 2024
    Level is not critical for cooling but is for draining condensate.  If anything, a little lean to the AC side helps assure the catch pan drains toward the outlet tubes.
  • ivorypearlcat
    ivorypearlcat Member Posts: 2
    year is 2024.  Will put something up the drain tube as suggested next time I am at the storage site.  I think it was possibly due to not being as level as we needed to be.
