Drivers side handle on rear of 2018 Tab 400 is loose-- tried to tighten screws & they feel like they are stripped.
Would longer screws with some kind of glue fix this? Anyone else come across this issue?
2018 Tab 400
0 ·
2020 Tacoma TRD Off-Road
The square drive screws are much less prone to stripping that Phillips in my opinion.
I'm guessing they're bolted through the aluminum ribs...but can't see the other side on the inside of the 320. You can barely see one of the threaded studs in the photo below (shown with the plastic cover removed).
