2020 Tab 400 Boondock Solo Question
Would a 2020 Boondock Solo be considered a pre-pandemic unit?  I've read that Nucamp build quality experienced a noticeable slip during pandemic era and I'm trying to avoid those years.
2024 T@b 400 Boondock | 2024 Honda Ridgeline | Dallas, TX
  • qhumberdqhumberd Administrator, Moderator Posts: 736
    You can check the build date on the label on the trailer tongue as that year was likely a 2019 build.
     My 2019 has a build date of Oct 2018.
    Bigger question might be the AC. The 2020 year was the Air8 year and many folks felt it could not handle heat and humid climates.
    FYI the CoolCat works great.
    Good luck
  • bayernfanbayernfan Member Posts: 46
    The 2020 Solo model received the CoolCat. I’ll ask the seller to check the label. Great idea, much appreciated.
