Must Inspect List for Used Tab
Would appreciate a list of things one should inspect when purchasing a used Tab 400.  I'd just like to know what the big ticket items are and the best way to access and assess them.
If a thread already exists for this, please share it.
2024 T@b 400 Boondock | 2024 Honda Ridgeline | Dallas, TX
    qhumberd Administrator, Moderator Posts: 915
    We bought a one year used T@B 400 now 4 years ago. We love it. I have since learned a lot on the forum about the issues that arise.
    So if I were to do it today:
    1. Document that Alde inspection and service have been done, with evidence that corrosion is not present.
    2. Ensure wheel bearing and brake inspection and service have been done, not just EZ lube. Check emergency brake pin for function.
    3. Avoid the Air8 which is undersized for hot and humid conditions. Look for a CoolCat AC and make sure it works properly and drains.
    4. Document battery care has been done. First owners often kill their batteries. A resting voltage after charging and load test will determine if the battery is in good shape.
    5. Check water pump, plumbing and hot water functions. Look for leaks, particularly around outdoor shower, which is a design that can leak behind the wall. Ensure low point drains operate. Pressurize with city water at proper psi and check as well.
    6. Check toilet function, black tank and grey tank dump valves.
    7. Check for proper drainage of bath sink. Another design issue depending on model year
    8. Check that tank sensors are functioning properly
    9. Check all electrical circuits breakers and fuses and the converter. Also inverter if equipped. Same for solar.
    10. Check stove and propane systems. Check fans.
    11. Check door and all windows and shades for proper functioning.
    12. Check for caulk age and cracks around round windows and at other joint areas on camper. Get underneath and check Coroplast cover.
    Thanks for the question as I now have my own check list for this year!
    Others will doubtless add more good ideas.
    Good luck.
  • bayernfan
    bayernfan Member Posts: 46
    Awesome list, thank you!
  • manyman297
    manyman297 Member Posts: 1,439
    Check rivets on frame especially where the tongue connects to the main frame. While not a problem with 400s there have been reports on 320s of this area cracking on the frame due to stress at this point.
    Also check for abnormal tire wear. Many Dexter axles have been defective and allowed a negative camber on the wheels causing inner tire wear. Camber should be 0 degrees.
    Check condition of all seals outside. Resealing is a pain and hopefully the seller has taken care of this item before selling it to you.
    2021 400 BD
    2020 Tacoma TRD Off-Road
