Awning needs poles. Anyone recognize this type awning?
elfintree
Member Posts: 3
Purchased a 2008 DM T@B and discovered the awning has no poles. Does anyone recognize the awning and know what replacement poles might work? Awning is thick and heavy. In good condition.
It is the silver version of this awning. They were an accessory for the Dutchman T@Bs. There was also a tent that used the same pole set and often the two parts are found separate - one without the pole set...
You might try looking/posting on this original T@B forum
https://groups.io/g/tabtrailers/topics
We really like ours...
Good luck!
2009 Dutchman Flower Power awning on our 2023 Ultimate Toys teardrop
Thank you for the suggestion. I will do that. Yours looks awesome!
That's the same design as the All Pro awning. I would contact them and see if you can purchase the pole set for a 320. The horizontal poles are adjustable, so those should work. You may need to adjust the length of one of the hoop poles to fit your fabric.
Note, your awning is installed upside down. The velcro tabs are on the bottom and hold up one end of the horizontal poles.Rich2019 T@b 400
Thank you for the information. I also appreciate knowing it was upside down. Very helpful.
- 916 Introductions
- 72 Teardrop Groups & Links
