New fridge door panel?
lkc001
Member Posts: 877
Hello all- previous owner had scratched up the door panel on the 2-way fridge in my Tab 400- has anyone replaced just the door panel & if so how to remove old panel & replace & where did you get the new panel -- OR what have you used to cover the door panel??
I tried to do a search but apparently not using a correct search term
Thank you
Thank you
2018 Tab 400
You could just put some peel and stick wallpaper over the front panel. Might be simpler and less expensive.
thank you for responding! After researching how to remove the panel on this specific fridge which requires removal of the door to access the screws on the BOTTOM of the door (instead of just having to remove trim from the SIDE of the door like many other RV fridges, which is really easy—duh)——I decided your option is going to be the easiest.XenanMe said:You could just put some peel and stick wallpaper over the front panel. Might be simpler and less expensive.2018 Tab 400
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
