Cabin not sealed / daylight behind the queen bed
Hello all, I woke up this morning and noticed there was daylight coming through underneath the head of the queen mattress. Looks like it goes to where the water hookup is. I have a 2024 T@B 400. Wondering if this is normal. Seems like an awful waste of energy in the summer so wanted to see if anyone had this going on. Thank you.
2024 T@B 400 Boondock
    No, this isn’t normal, or at least shouldn’t be. It was the same on my ‘23 Tab 400. I sealed it up. This should have been sealed when being manufactured
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,486
    If you are talking about where the Nautilus and the outside shower is, that would be a possible area to look at.  Time to take the bed up and have a look.  Have someone outside with a flashlight pointing towards that area and you should be able to sort out the spot.
  • CrackerCracker Member Posts: 30
    Should there be some sort of interior cover over the Nautilus?  With the bed raised in my 2021 400 Solo I can reach right into the Nautilus box.  Woe be you forget to close the outside hatch and mice or squirrels discover your error!
