In May 2024 I was running the Alde heat at 4100 feet in elevation on my 2022 Tab 320CS (Alde is version 3020). I saw a lot of water/condensation dripping out of the Alde exhaust.
Is this a symptom of a problem? Have any of you seen this?
Here is a short video:
https://vimeo.com/1017752570?share=copy#t=0
The burner is surrounded by the heat transfer fluid, if that is disappearing then it is a problem.
