We were on a trip two weeks ago and had stopped at a Finger Lakes winery on a sunny day. When we returned to our car I checked the Victron Connect app and saw that there were zero watts of solar reported being produced, even though we had parked in full sun. I checked the SMP disconnect and saw that a wire had pulled out of its eyelet connector and figured that fixing the issue would be easy - simply get the wire crimped back into its connector. But it wasn't so.
The yellow disconnect indicator on the SMP was not visible and I can't remember if I pushed the blue button or not before loosening the hex nut to remove the eyelet connector. I managed to get the wire pushed back into its hole in the connector and crimped it down as best I could with pliers, then put the connector back on the threaded stud on the right hand side of the SMP and tightened the hex nut. Since then there continues to be little to no PV production per the Smartsolar app. I've checked and rechecked the various fuses that are obviously involved in solar to battery charging - the 30 amp at the SMP, the 30 amp at the MPPT and the 30 and 3 amp fuses at the battery. They're all intact.
Today I checked voltage at the SMP 30 amp fuse shown in the photo and saw 10v DC on a multimeter. For the past two weeks the MPPT has only displayed a slowly blinking blue Bulk indicator light. Testing current at the MPPT, I read 13v plus or minus at the Battery connections and zero at the PV connections. Should I interpret that to mean that there is no solar voltage getting to the SMMT? Could the SMP have failed, perhaps related to the disconnected wire? Is the MPPT not functioning? The battery SOC is slowly dwindling, down now to 72% at about 13.2v. I'll plug into shore power this evening to charge the battery.
If anyone has some insight into what's going I'd appreciate hearing your thoughts.
If you look at the screen shots you'll see that 11 days ago, October 1, we had normal solar charging which included 56 minutes of float time and 15 minutes of absorption time along with 4hr 20min of bulk time. This was the day that we visited the vineyard and I found the disconnected wire. Every day after that shows varying Wh and volts generated but starting 10 days ago the app shows no float or absorption periods, just bulk periods. this is why I'm concerned that perhaps the disconnected wire triggered some malfunction in the solar charging function.
11 days ago was normal - float, absorption and bulk periods indicated by 3 segment column
Here's 11 days ago expanded to show values of the 3 segments
10 days ago - only bulk time shown, continuing through today
Today
2024 Kia EV9
Bottom of unit, wiring only - red & white on the left to battery, green & white on right go to PV terminals
The 2 green wires go to a 30 amp fuse which doesn't look blown
2024 Kia EV9
@pthomas745, I have done several iterations of your suggestion to remove all power from the controller/charger by removing all fuses - the 30 amp at the battery, the 30 amp at the controller shown in my photo, and the 30 amp on the wire that became disconnected. It is this fuse that appears to totally shut down the controller. Then I installed the battery fuse first and looked for recognition by the controller but at each iteration that I've done, the Victron Connect app shows nothing coming to life in the Smartsolar portion of the window. It's as if there's no device to recognize the battery. The Smartshunt portion displays normally.
Next step was to install the fuse at the controller but still nothing displayed for the Smartsolar portion. Finally I installed the fuse at the disconnected wire and then the Smartsolar readout appeared, but still without any indication of solar activity. The History page for today shows no bar graph, 0Wh for yield, 0W for P max and .2v for V max. It's as if the panels are not generating power - or the controller can't recognize it.
I've had the camper parked in the sun all morning and have been running the roof fan and several lights to put a load on the battery, trying to drain it down from the full charge it got last night on shore power, but if past history when I let the battery drain to 72% SOC is any indication and solar never showed signs of life, I can't help wondering if the controller needs to be replaced. I mentioned earlier that I tested voltage at the fuse holder on the disconnected wire and saw 10v by touching each contact in the holder with multimeter leads. I was in the shade then two days ago. Also, when I reinsert the fuse there's generally a bit of sparking which would seem to indicate that there is power coming from the panels. Maybe time to order a new controller? What do you think?
2024 Kia EV9
If you measured voltage across the contacts in the fuse holder near the breaker it does not yield any useful information.
To make sure the panels are ok try the following: Remove the fuse for the panels near the solar controller, then measure voltage between the - terminal at the controller and the contact in the fuse holder that goes towards the panels. In sunlight you should see close to 25V.
Just did it and saw 17.3v with panels shaded. That jibes with what the app shows for today's max voltage, but there's still no Wh yield being recorded. Any other tests you can think of to verify controller state of health?
2024 Kia EV9
2024 Kia EV9
2024 Kia EV9
2024 Kia EV9
https://www.victronenergy.com/upload/documents/Manual_SmartSolar_MPPT_100-30__100-50/29694-MPPT_solar_charger_manual-pdf-en.pdf
2024 Kia EV9
Good luck...
2024 Kia EV9
2024 Kia EV9
