I have a 2019 Nucamp 320s. For the first time we are going to boondocking. I know that I can run the Heater, and the fridge with our propane tank. I'm guessing that I can't run the AC, nor the lights...or that they will try to run off of the battery. So we have a blackstone grill, so I'm guessing that I can't run that, unless i have some sort of inverter to run that. Can someone help with how best to boondock with a Nucamp.
Going on Wednesday.
1 ·
The only things that don't work on battery-only power are: Alde on electric mode, air conditioning.
You may just want to look for some things to heat on the stove in the camper using gas. You WILL NOT run through a full LP tank over a weekend using ALDE, fridge and cooktop. Battery can be close if you aren't careful with what you use (lights, fan etc.) or resupplying it somehow.
Relentlessly Pursuing a 2025 Silverado EV
Racing the Wind and Chasing the Sun
Virginia Beach, VA
I basically use all of the techniques described above. My 12 volt fridge was on the entire time. I watched a little TV, used my lights, used the shower a few times, did dishes, and ran my roof fan quite a bit. Hope this helps!
2024 Kia EV9
another issue we were seeing on the pump for pushing grey water… it was really pretty loud and vibrating the camper. We have used the pump before on shore power and didn’t have that issue.
the other issue we are having at Assateaque is the one plant age with burrs…that is playing. Havoc with our pups…which is crazy. They seem to be everywhere…🙄
