Alde heat system in 2022 T@B 320S heat ports
Hello,
I am trying to figure out where the various heat outlet ports are for our T@B.  I suspect I may be inadvertently blocking one or more of them due to how slowly the trailer heats up (using propane).  Is there a diagram or description someone can provide that I could look over?
Thanks in advance.
Harry
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,485
    The Alde is "radiant" heat.  The warm glycol is pumped around the trailer in the glycol hoses. From under the driver's side bench, the glycol travels to the back of the trailer behind the bed, and warms the convectors there.  That heat radiates up through the long thin "vent" at the back of the cabin.  The glycol then travels to the passenger side to the convectors under that bench.  If you look towards the floor along the bench areas, there will be small "cutouts" along the wood frame that act as vents to allow the warm air to escape and enter the main part of the cabin.
    Take care not to cover the "back" vent behind the bench area, and those little cutouts along the floor.
    There are threads about this, but finding pictures is a bit difficult.
    This thread has the general layout and a diagram of a newer CS and the flow of the glycol and location of the convectors, etc.
  • JHornbyJHornby Member Posts: 19
    PThomas,
    Perfect, thanks so much!
