Wireless Solar Powered Rear View Camera
After several years of pulling my 320 T@B across this country, I finely found a simple, inexpensive and easy solution to rear view: the  Auto-Vox Solar1 PRO-XG Wireless back up Camera! Stainless steel bolts and cap nuts were all that were required to hold it on. For Set-up: I had to flip the camera to work with the lower license plate holes - just Enter the menu, you will see the M/U Control, press M button, press up or bottom to select the Upside image, press M button to confirm it. It was that simple. The range between the trailer license plate and TV dash board exceeds the advertised 35'. This makes it a sure thing pulling a T@B! We tested it on a long weekend and it performed beyond my expectations.
The image is actually better then my camera caught
Clean and unobtrusive
California, USA
  • SLJSLJ Member Posts: 635
    They come in handy. I added a wireless Garmin back-up camera to mine. Gets it's power from the T@B's running lights and the transmitter is mounted on the front of the T@B so I get a strong signal. Displays on my Garmin RV GPS so I don't need a separate monitor.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2023 Ford Maverick XLT
    The Finger Lakes of New York
    Good for you and they are handy! - I just swapped the wiring for the small solar panel
    California, USA
  • CatDaddyCatDaddy Member Posts: 134
    How did you choose this particular system? There are something like four million options on Amazon. I got overwhelmed and gave up. Do any of them integrate a TPMS system?
    2022 NuCamp T@B 320S Boondock
    2023 Volkswagen ID.4 Pro S Plus AWD
    I was a little overwhelmed with choices too, so I googled "reviews of" and this unit was top rated by several sites. This is a stand alone system and I do not remember seeing a back-up/rear view camera/ TPMS  unit. This unit is entirely wireless
    California, USA
