ARB Dual Compressor > winterization kit
donmontalvo
donmontalvo Member Posts: 187
First camper (nuCamp T@B 320S Boondock Black Canyon. I had to build a winterization kit from scratch. I already had a compressor. I thought I'd share.
[$41.41] VIAIR 90145 RV Winterization Kit
https://www.amazon.com/gp/product/B07DQGNC6H
$5.99] 3/4" Brass Garden Hose Shut Off Valve,1-Way Restricted-Flow Water Shut-Off, Fits 3/4 Inch Hose Connector
https://www.amazon.com/gp/product/B081NHL9FC
[$12.29]
Flexzilla Garden Lead-in Hose, 5/8 in. x 5 ft., Heavy Duty, Lightweight, Drinking Water Safe - HFZG505YW
https://www.amazon.com/gp/product/B01D51VBFS
  • swiftwave
    swiftwave Member Posts: 50
    Nice kit and parts list.  Very similar to the kit I assembled a few years ago and have used with good success ever since.
    After blowing out the system with regulated air pressure, I still use plumbing antifreeze through the water pump and the toilet, as I heard these components are the most susceptible to freezing damage.  Best of luck with it…
    2020 T@B 400 Boondock Lite.
    2020 Chevrolet Colorado ZR2
    with the 2.8 litre 4-cylinder Duramax diesel.
  • donmontalvo
    Those are the remaining steps I need to wrap my head around. A few days ago it got down to 20 degrees. I didn’t have a kit. So I drained everything and left everything open.
    pthomas745 Administrator, Moderator Posts: 4,694
    What year is your trailer?  The newer trailers have cassette toilets, and different Hepvo sink traps.  The pump is very simple to drain and clear water from.  Lots of threads on this, so: what year is your trailer?
  • jkjenn
    jkjenn Member Posts: 6,425
    [$12.29]
    This is exactly my setup.
  • donmontalvo
    [$12.29]
    You have an ARB dual compressor?
  • donmontalvo
    2024
