Installing microwave in 2022 Tab 400
TimberjackTimberjack Member Posts: 9
Hi all.  Looking at a 2022 Tab 400 that came from the factory without the microwave.  I would like to add a microwave (same model that Nucamp utilizes). Is the microwave hardwired or plugged in?  Are connections (ie outlet) present even if the trailer came from factory without a microwave?  Thanks.
  • subkronsubkron Member Posts: 173
    I removed mine since we never used it anyway and picked up some additional storage. The stock microwave was a 120V with a standard 120V plug. In your pic above the microwave was in the left compartment and the cord routed through the divider via the hole and plugged into the outlet in the right compartment. If that pic is the 400 you are interested in then you are set to go, sans microwave.
    2022 T@B 400 Boondock
    South Jersey
