Where to buy Wheels and Tires
My Pull-T@B 2014 320CS did not come with a spare. I want a full size spare so once it is on and torqued, I will be good to go for a while.
I found the wheel on Tredit.  It turns out to be the same wheel they use today.
I am looking for retailer options. I need new tires, so I might buy all three and a wheel if I can find a good deal on them.  I know I can buy it it from the Dealer, but at the maximum price.
Your suggestions will be greatly appreciated.
We are not new to trailering but we are new to the T@B community.
2019 320CS
No Frills Trailer Camper
Pahaque Trailer Tent
"This space left blank for lack of inspiration."
  • Cherokee
    Cherokee Member Posts: 346
    I just placed my trailer on jack-stands and took the tires & wheels to American/Discount tires. I bought TOYO Open Country tires the same size as the originals. I had them mounted and balanced. I saved money over replacing them with stock trailer tires and passenger tires and Light truck tires meet higher standards then trailer tires. They would let you pull your trailer to them, but I'm just not comfortable with tire tech's removing and replacing my finders
    California, USA
  • CokeZero
    CokeZero Member Posts: 3
    Thank you!!!  I have a local shop here where I buy all my truck and Jeep tires.  I will reach out to them for tire pricing.  Since you are in a Boondock, do you have 14 or 15 inch wheels?
    2019 320CS
  • Cherokee
    We have 15" wheels: 235/75/r15 which match the largest tires one can place on an XJ without a lift. I believe your CS comes with 14 " wheels - you might pick out your size tires on the web and then have your shop order them. Which Jeep do you own?
    California, USA
  • Slackers
    Slackers Member Posts: 490
    We ordered our Carlise (now Carlstar) Radial Trail HD All Season ST205/75R14 100M tires from Walmart. We shipped them to our local Walmart who mounted and balanced them for a nominal fee. Like @Cherokee we jacked up the trailer and had it rest on jack stands while the work was being done.
  • CokeZero
    2014 JKU Sahara
    ST3 TeraFlex lift
    Yukon 4:56 turning
    BFG Ko2 35/12.50s on AEV Salta Wheels
    I know a lot more about Jeeps than Trailers.
    I don t want the expense of three new wheels and tires. I just have not found a truck or trailer tire that is remotely all terrain in a 205-15.14  I may have to go to a 235, if it'll fit comfortably.
    2019 320CS
  • Cherokee
    edited February 2025
    CokeZero said:
    2014 JKU Sahara
    ST3 TeraFlex lift
    Yukon 4:56 turning
    You might have better luck fitting 215/75r14's without a pinched axle. They are only 1/2 an inch taller while 235/75/r14's are 1-3/4" taller then the 205's and will undoubtedly rub. But again, you may have to settle for an all-season tire. I have KO2's on my jeep and General Gabbers on my truck. The CS doesn't have much of a departure angle anyway
    California, USA
  • Slackers
    Mind the bolt pattern for any new wheels.
