This was unexpected, I fortunately was traveling with a nearly empty freshwater tank (less than third but reads E now.), and very little water in the grey tank. I’ve been driving at least 6 hours in below freezing conditions I did not plan for or prepare for, I’m in it for 3 days. Plans I can’t change. I’ve done no winterizing. When I parked for the night I was able to connect to 30 amp electricity. I’ve got the cabin warming up, I set the heat priority to propane and started getting an increase in glycol temps immediately. I’m at 51 F on the inside after an hour but it is still increasing. My question, is there anything I can do now to prevent damage to the water system? When I first opened the door I found an icicle hanging from the kitchen faucet. Am I just out of luck have to hope for the best?
note: 2023 320s Boondock
                2023 T@B 320s Boondock, 2013 Toyota Tacoma TRD 4x4
John, Northern California
0 ·
Best wishes to you.
If you can get a small air compressor to hook up to your fresh water inlet you might blow out the lines after draining the tanks.
SW Montana USA
Seeing as you were in freezing temps with no heat for 6 hours it probably is unlikely the alde was affected but the icicle on the faucet is evidence of just how cold it was inside the camper.
2020 Tacoma TRD Off-Road
