I am preparing for my first spring outing with my Black Canyon T@B 360. The  solar system remains a bit of a mystery to me. Sitting in my driveway here in Maryland the solar panels aren't keeping the system topped up to 100%. The only way to stay charged is the shore power. My previous T@320 with 200 watts solar and 300ah of AGM batteries was easily kept charged in winter without shore power. I had that for five years. My new camper is sitting on the north side of my house so it doesn't have direct sun, but it does have full exposure to the sky. This should bring in more than the 15-88 watts that the system says it is providing.
The dealer has told me that because the lithium system needs to run the battery heater, the solar panels can't keep it charged. To me, this means that the lithium upgrade makes the T@B 360 less effective as a camper for the cooler shoulder season because the solar system can't keep up with the battery heater.
What am I missing? Is there something wrong. I do have experience with solar panels and with T@Bs, so I don't think I am crazy, BUT I haven't worked with lithium.
                T@B 360 Black Canyon, 2021 Jeep Grand Cherokee V6, Maryland
(previous 2018, T@B 320 Outback)
1 ·
Edit to add: You'd only need to use the heaters when trying to charge below freezing. The internal electronics should shut down an keep the battery from charging if the temp is too low. At that point you'd turn on the heaters.
Relentlessly Pursuing a 2025 Silverado EV
Racing the Wind and Chasing the Sun
Virginia Beach, VA
Hope that I answered your question...
Virginia Beach, VA
Southern Maryland
https://www.victronenergy.com/battery-monitors/bmv-702
one thing I have discovered is that when the inverters is on, there is an exhaust fan that comes on and is quite noisy. For the shore power to work, it appears that this fan might need to be on. I will need to do something about this.
Inverters can generate quite a bit of heat, hence the need for the fan. It looks like NuCamp also installed a small standalone fan in the compartment. I also installed a small computer fan near my inverter to move warm air away. Unfortunately, even small fans can be noisy. If you are not using the inverter, you can turn it off. Although the fan may also be for the battery charging system of the multiplus.
Looking forward to any additional pictures you can supply.
Southern Maryland
At this point, I'd opt to add my own additional batteries and inverter and tuck them under the driver's side bed.
Regarding the location of the battery, I believe it is under the passenger bed compartment. I will have to open it up and double check but I believe we saw that in our walk through.
I haven't gotten down under the camper to take the panel off and take any pics, but I have gathered some data. As you know, the solar panels are 380 watts combined. I'm not a fan of the long thin format running front to back with195 watts each. That means each of them are compromised by the performance of the side away from the sun. More, smaller panels could have been configured for better performance in a wider variety of conditions. Here is a picture of their performance yesterday.
Super-bright sunny day in late March at around 12:00 or 1:00. The 380 watt panels made 207 watts.
Just two-hours before at a partly sunny 10:00 they were seeing only 4 watts. Terrible!!
The Lithium package has the Battlebornmodel BBGC3H 270AH Lithium Battery. With this marginal performance, I am not sure that I would be able to recharge the battery after a night of heavy use.
My critique isn't without experience. I had 200 watts of solar on my TAB 320. Two were in series and two and parallel. They sat on top of the camper and were paired diagonally. They were great from morning to evening.
The most significant difference is the amount of power I have. I had 450 AH of AGM batteries and comparing recharging of AGM to recharging of lithium is probably unfair. the battleborn claim a depth of discharge of 100% (whatever that means). AGM batteries probably had less than half that 450AH available to them.
Camper: nuCamp T@B 320S BBC 480W solar and 200ah LiFePO4
TV: JLUR | Tow Package | 100ah LiFePO4 | 200W Solar | DCtoDC
https://revkit.com/donmontalvo/ | https://donmontalvo.com
What models of solar suitcase are people using?
