Keder rail mayhem
So I've tried 2 different Amazon products listed to work with 8mm awning track and both are far too small to stay in the track(they are only 6mm diameter). I think I have found the one that will fit but it's only the stopper, not the one with the eyelets. They arrive tomorrow and I'm hoping to find the 4m eyelet screws at home depot. Anyone here actually find a set that is both the cylinder and eyelet that fits the 2022 T@B 400? Thank you all for your generous sharing.
2023 T@B 400 Boondock
2015 Taco
  • WayneWWayneW Member Posts: 236
    I also could not find the right ones without ordering both the stoppers and eyelets. These worked for our 2021 320S. I think it has the same keder rail.
    Google:  “Create idea 4PCS Awning Rail Stoppers 8mm for Campervan”
    These are the stoppers
    Then order the eyelets:
    12 Pcs M4 Lifting Eye Bolts, 304 Stainless Steel Male Thread Machinery Shoulder Ring Eye Bolt Heavy Duty
    Kind of a pain to have to order both but they worked for us.
    2021 320S BD
    2017 F-150
    Coeur d'Alene, Idaho
  • TourDeForthTourDeForth Member Posts: 79
    These are the ones I used to mount an awning to my 320s Keder rail.
    https://www.amazon.com/dp/B0D3WRRCN1?ref=ppx_yo2ov_dt_b_fed_asin_title
     They are 8mm and have held up so far. They fit loosely until the wing-bolt is tightened. Then they hold snugly. I haven’t searched for an eye-bolt version but I’m guessing a matching thread could be found.
    2023 T@B 320s Boondock, 2013 Toyota Tacoma TRD 4x4
    John, Northern California
