2022 Tab 400 boondock brakes
Purpleheart15Purpleheart15 Member Posts: 5
I keep seeing conflicting information on what replacement brake assemblies to use on my Tab.  There is no way to see the tag on the axel without removing the shield.  Will the 3500 lb brake assemblies work or do I need to use the 4400 lb?
Thank you for the help!
  • CherokeeCherokee Member Posts: 299
    Most trailer supply stores carry a Dexter 10" or a 12" Drum assembly. Simply match the size and bolt on & splice the wire and play
    California, USA
