Hi all, while driving in Arizona withour 2017 T@B 320S, I wrangled with a road gator, and had the passenger side wheel skirt get torn off and destroyed.
Does anyone know of any sources for a blue skirt that matches our T@B?
I've found one that looks correct from IconDirect.com (aka Lookup-our-skirts.com, cute) at
https://www.icondirect.com/t-b-single-fender-skirt-fs4432/This looks promising, but is only available in gray and red, and also looks a little textured, not as smooth as the original. Has anyone tried these skirts for their T@B?
My wife is also trying to contact Nucamp directly, but we're still waiting for a response.
Any other suggestions of places to look?
thanks in advance for any advice you can give,
Jason.
In case you find a skirt in a different color, I've had very good results using the Krylon brand of paints. The gray in the photo matches my gray trim perfectly. Apply a few coats of paint, then follow-up with a few coats of clear. You should also be able to sand-off the rough pebble texture.
