I know there are several discussions about towing with a Tacoma, but will ask anyway.
Just finished a weekend trip along the Gulf Coast towing our 2016 TAB CS camper with my 2023 Tacoma (V6 engine, automatic transmission). Most of the terrain is flat or moderately hilly but felt like the truck was working harder than it should to keep about 70 mph highway speeds. I would be having to rev up to 3k rpm at times on the hills and my milage was between 13-14 MPG.
I wanted to know if this is typical or if I should be towing at a lower speed or at least what other people's experience has been with a similar setup. The truck is rated for 6500lb towing capacity, I feel that a less than 2000 lb camper should be no problem.
0 ·
Maximum Torque is attained at 4600 RPM
Maximum HP is attained at 6000 RPM
Further point, you should not allow the transmission to shift to over-drive.
That gas mileage is about typical.
and I could have worded that better, but:
The power needed to overcome drag is the product of the drag force and the object's velocity. Since drag is proportional to velocity squared, and you're multiplying by velocity again, the power needed to overcome drag increases as the cube of the object's velocity.
It's a remarkably complicated subject, mostly above my head, but either way, it's a real drag!
Also towing a 320s with a 2023 v6 Sr5 4wd longbed tacoma automatic, heavily loaded with gear. 11-13 mpg towing 70 to 75 mph. 14-17 mpg without tow. 87 octane efuels.
3000 rpm is about 70 mph in 4th gear.
You are hopefully in manual "s" mode not automatic. We never use fifth gear overdrive except long steep downhills.
I never use sixth extra overdrive, period. You'd have to be doing 85 untowed to not lug the engine rpm.
I recommend getting a Scangauge III that plugs in OBD port and can be setup to show actual gear you're in, transmission temps, oil temp.
If you haven't beefed up leaf springs they are negative and bottomed out on all stock tacomas carrying 400 lb or more.
You need add a leaf (AAL) helpers, bigger springs, or I recommend Firestone airbags which are adjustable with one press of a bicycle footpump.
8 to 10 psi out of option for 40psi levels us out.
Just put in a transmission aftercooler and did transmission flush at 30k miles of which 25k has been towing. Also pinned the transmission thermostat open for towing season. A big job overall.
12 to 20 degree F reduction in transmission fluid temperature. 194F is median oil temp. Transmission fluid is no longer in that range but 168 to 174 full day highway drive. Fluctuates higher with hill climbs.
Lots of good info on Tacoma World forum. I've put several hundred hours into mechanical and electrical mods related to towing camper and construction trailers.
2020 Tacoma TRD Off-Road
