Tab 360 Jensen TV
levbob
Member Posts: 27
In a new Tab 360 there is a black panel with a switch, when pressed a green LED comes on. What is being turned on? An antenna for TV?
Or to get TV over the air do you have to plug an external antenna into cable jack in Nautilus?
Any help appreciated. No manual or info came with Jensen TV.
Yes that switch let's you either use an external cable that goes into nautilus or your on trailer body antenna. It's a toggle switch. I think the green light is for on camper antenna.0
Where is this toggle switch surprised I had not noticed it0
push button switch on wall panel behind TV. no idea what it does0
