Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
Standard Lagun Table Size for 320 and 400
Jf05
Member Posts: 1
Hello - I've searched but can't seem to find the standard lagun tabletop size in either the 320 or 400 models. Would anyone be able to provide those measurements?
Here's the table in our 2024 T@B 400 - 24.25" square by 1.25" thick.
Susan & Bill, Yarmouth, Maine
2024 Kia EV9 -
I believe the original table in my 320S was around 15" x 29". I'll climb up in my garage attic tomorrow and check for sure.
I made a new, wooden top and wanted to maximize the size, so I made it 15" x 35". With rounded corners, it just clears the corner of the bathroom wall when rotated. It's a bit on the heavy side, so I drop it down and support it on the bench cushions when I travel...to make sure it doesn't damage the mounting hardware.
15" x 28" for a 2024 320 CS-S
Good memory Basil and nice work on the replacement!2024 320 CS-S | Ontario, Canada -
@HappyWanderer - Thank you!
- 916 Introductions
- 72 Teardrop Groups & Links
- 913 Tips & Tricks
