I'm sure this has been covered, but I haven't been able to find the specific information.
I am installing two, new lithium 12v batteries, in parallel, into my 2021 T@B 320S.
Due to all of the issues I've seen on this forum, I am not changing out my converter. My plan is to let the old converter charge the batteries to around 85% (or whatever it ends up being), then letting my solar panels charge them up to 100%. I realize I need to change my solar controller settings.
Lastly, in the event we have little sun, I purchased a Victron external battery charger. Because I shouldn't need it very often, my plan was to simply connect to my installed batteries with alligator clips and then remove them when complete.
My main question: Will turning off my factory battery disconnect switch be sufficient to isolate the T@B while charging with the Victron? I know there are a few items that are powered outside of the switch.
Thank you in advance!
0 ·
My T@B sits in my driveway while not in use. Due to small parasitic draws, the batteries drop down a few percent at night, then the rooftop solar brings them back up to 100% during the day. Is this a good practice? I've been over-whelmed with the information on the internet...so I'm not really sure.
2025 Toyota Tundra / Nashville, TN
