repairs to new Tab 360
levbob
Member Posts: 26
To close the loop on reporting on new Tab 360. Bought in May. Pump ran continuously when switched on. Boondock lithium battery state ofcharge dropped to zero. Repaired under warranty. Loose filter so pump was sucking air - fixed. Several wires to Victron shunt wrong from factory - wiring fixed,now charging and state ofcharge increasing.
I told them nearly a year ago that they were wiring to the wrong side of the shunt. Kind of a head scratcher.
sad to hear - glad I bough in 2019TV:2019 Nissan Frontier PRO-4X With an Old Man Emu liftTrailer: 2019 T@B 320 Boondock with a Lock&Roll Coupler & Jack-e-upCustom fabricated metal bottom claddingCalifornia, USA0
From what I recall there are still reports of them still leaving too much slack on the electric brake wiring so it rubs against the tires. This was happening way back in 2021.
2021 400 BD
2020 Tacoma TRD Off-Road0
