After a couple of boondocking camping trips, we’ve discovered that the onboard 380w of solar panels aren’t enough to keep our batteries topped off up here in the Northeast. We often camp in spots with less than ideal sun and some overcast. Most of the time we are only seeing 50-60 watts coming into the system. During the “Prime” sale, I picked up an Ecoflow 220 Bifacial suitcase to supplement our existing solar. The unit I bought does not have a built-in controller. I know I need to add a controller, but I am curious about the best way to do that in our camper. The Nautilus is the obvious place, but I am concerned about adding a controller on the interior given the limited space and my very limited understanding and experience working with electricity. I’ve read almost all of the related threads, but most of the conversations deal with older setups. I am reasonably handy, but definitely intimidated by volts/amps/watts and the like
Can I get some recommendations on how to install a second controller? Specifically should I rewire the existing Nautilus port (based on my limited experience but a willingness to learn) or add an external controller before the Nautilus? I’d like to keep it in the Victron family if possible to make the monitoring as easy as possible. Or is there another option I should consider that I haven’t mentioned? Thank you for the help.
Can you provide a photo of your batteries and the wires that connect to the Nautilus port? I'm guessing that your batteries are under the passenger side bench seat and that the auxilliary port is wired directly to the battery. If possible, I would mount the new controller in that space, using the existing wiring from the port. It's always best to mount the controller as close as possible to the batteries.
I added a 200W Renogy panel and a Victron 100/30 controller in the propane tub (that's where the batteries are in my 2021, 320S). I like the Victron products and the second controller works really well with my orginal Victron.
Sorry, I meant to include this simple wiring diagram as well.
I put two circuit breakers underneath it, so I can disconnect and reconnect, in order as per best practice.
https://donmontalvo.com/wp-content/uploads/2025/05/20250520-camper-schematic.png
Camper: nuCamp T@B 320S BBC 480W solar and 200ah LiFePO4
TV: JLUR | Tow Package | 100ah LiFePO4 | 200W Solar | DCtoDC
https://revkit.com/donmontalvo/ | https://donmontalvo.com
The OEM wiring seems complex at first, but once you start doing a point to point wire tracing it will become clear. The huge advantage of doing it yourself is your really get to know your system (easier troubleshooting) and you know components along wire and fusing are sized properly (and it's fun).
Here is a great site to read posts of others who did the same work. You will learn a lot that way. Vehicle Mounted Systems | DIY Solar Power Forum
A lot of good installation videos here. Look in the beginners section. EXPLORIST life Mobile Marine & Off-Grid Electrical - YouTube
One other thing, IMO watch for knockoffs of electrical components on Amazon. For me, when it comes to electrical components, it's worth it to buy name brand parts for a bit more,
Southern Maryland
