Victron app on Tab 360 - don't see what the manual shows
On a 2025 Tab 360 with Boondocks option, I don't see the window on the Victron Connect app shown on page 51
on the Tab 360 manual.
The manual says "The button the on left will allow you to limit how much amperage you can draw from your shore power
source. By default, it will be set to 30A as the trailer uses a 30A inlet plug. However, you may want to
change this limit temporarily if you are on a 20A or 15A outlet to prevent tripping the breaker on your
power source.
The button on your right will allow you to change the Multiplus operation mode. By default, this will be
set to ON which means both the charging and inverting functions are active. However, you may want to
change this to Charger Only in some circumstances to save battery power. This will temporarily disable
the inverter, which pulls 1-2A on average while powered on."
On my smart phone I see the solar device and I see the shunt.   Should I see a third device?  the Multiplus?  and that is
where there is control as manual indicates?
Thanks for help.
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,503
    This all depends on what exact setup you have.  NuCamp is very vague with their descriptions of 'lithium packages", so there can be many variations of wording and equipment.
    The description you are getting from the Manual is for the Multiplus inverter charger.
    So, everything depends on what exact battery you have. This thread says the trailers with the 270 amp hour battery have the Multiplus inverter.  And, this comment.
    "I asked Nucamp about where things go if you get the Lithium package.  Sounds like instead of getting extra batteries, you just get a bigger, single battery (270ah)....which is installed UNDER the camper...
    From Nucamp:
    "The Victron MultiPlus inverter/charger is installed on the inside of the under the bench seating. The 270amp Battle Born lithium battery is installed on the underbelly on the outside of the unit close to the axle, you would have to remove a panel to access"
    There are other comments in that thread.  Keep in mind, the 360 is very new, and there have been and will be "running changes" as NuCamp tweaks the design.
    This thread has some photos of a 360 "Black Canyon With Lithium Upgrade".  Pictures of where the Multiplus is and what it looks like, etc.
  • Gomers2Gomers2 Member Posts: 109
    I'm not sure of your intent in limiting the current draw or what you are trying to power from the 15 amp circuit but there is a way to limit the air conditioner draw. On the Alde screen inside the trailer under the electrical settings Sub menu you can limit the AC draw to 1 KW. I don't have access to the trailer right now but it's a little slider left to right to set the maximum 120 draw.
