Hi all,
After a lot of searching without luck, I am wanting to identify the plug just inside and forward in the cargo bay passenger side in my 2019 400. I am going to remove the battery box to replace the existing dual 6V AGM batteries with a single 230 amp Hr Lithium that has a slightly smaller footprint. I am a novice electrician at best.
When I was scoping out the compartment to plan removal of the battery box I found the plug pictured below. It looks like an AC plug but as I have the 12 V frig I don't think its that. It is right below the TV so maybe the TV? It is just forward of the battery cutoff and Gloso switch.
I ask because I have been researching ways to best manage the recharge of the new lithium, and I didn't want to get into the converter. So a simple 10 amp lithium charger that I can plug in when on shore power to top off the battery seemed a good option. I also have a 100 W solar suitcase and SAE type connector but can't always access this when in storage. Hoping the plug pictures could be modified to a duplex plug and thus provide the power I need for the charger. I was thinking that when plugged into shore power I could disconnect the battery and plug in the small charger. Wondering if it was kept connected when battery on and converter on there would be any issues.
A couple of pictures are attached. Sorry if this has been answered already but I could not find it.
Thanks
I have read that this out was powered by an inverter in some models, but mine did not have an inverter installed.
So before I started taking panels and bed sections out, thought I would check.
Here are a couple pictures from the foot of the bed side. In one you can just see the cord running up behind the battery vent hose
Good to know that the idea of finding an AC outlet to power the small lithium charger can work. Just need to pull some panels and get my tester out and see what is what.
Any issues with having the WFCO converter/charger and a small lithium charger both connected to the new lithium battery at the same time? I think I can mitigate that by unplugging or by having the batter disconnected so only the lithium charger is powered, but would there be an issue if both happened to be powered and connected to the battery?
I never had an inverter, and the outlet at end of bed is a regular shore power AC. You can see the plug and wire in question in that link, but it doesn't add much to what that plug in the cargo area is powering.
https://tab-rv.vanillacommunity.com/discussion/9453/inverter-outlet-tab400
Based upon the location it did not seem anything else was near enough to need a plug. Seems like adding an outlet dedicated to my small lithium charger will be the way to go for this lithium upgrade. I will confirm with the Converter panel to ensure that is the correct circuit. My converter breaker shows the frig and microwave on a 20 amp AC breaker, if I am reading this right:
