not sure of part numbers for Dexter stuff
Is the Tab 360 Boondock brake size 10” x 2 ¼”. So spare magnet is Dexter kit K71-104-00?
Does the Tab 360 Boondock use standard of EZ Lube Seals? Seal kit K71-303-00? (which is for 10” x 2 ¼”)
Which brake show replacement kit is correct? K71-047-00?
Which bearing replacement kit? K71-390-00 inner bearing for 10” x 2 ¼” 3.5K axles, K71-306-00 for outer bearings?
Cup/cone LM67010/LM67048?
