Lithium Battery High @ 80 amps. Later this will go away.
I was down to 56% charge after being on the road a few days. My Lithium charge on my 1023 T@B BD says it's drawing 80 Amps. Why?
  • elbolilloelbolillo Member Posts: 529
    You are actively charging. That is the voltage and amps for charging, not drawing. You are looking at the Victron inverter/charger screen.
  • rcarlson1957rcarlson1957 Member Posts: 235
    MarineFriend If you have multiple Victron devices sometimes it's easier to rename them so you can clearly see what they are vs the default that Victron uses. I made that mistake a few times till I changed them.
    Trips - 48  Mileage - 63,452
