Norcold Fridge constantly running
S810
Member Posts: 4
The Norcold 2-way fridge in my 2019 Tab 400 Boondock is set to zero but constantly runs. I cannot get it to turn off completely so is this normal? Any information or experience would be much appreciated.
Disclaimer: No direct 2-Way Fridge experience.
A yr-2019 TAB 400 most likely has the Norcold NR-740 series Fridge.
nüCamp installed these to operate on 12VDC only, when on Shore Power the WFCO Power Center not the battery powers the Fridge { not valid for yr-2019, occurred during a later production year. }
NR-740 User Manual states when the Thermostat is set to " Off " the Fridge is off.
Assuming your reference to " Zero " means the Thermostat is at it's lowest setting (off)
then it seems your Thermostat has failed ( a common failure BTW )
Replacements are available for around $35 on the web.
Do confirm your Fridge Model Number before ordering.
Until a replacement is installed. . . .
Your trailer may have a 12VDC Power to Fridge toggle switch,
turning it off will stop the Fridge operation.
If not on most rigs the DC Fuse panel position #9 feeds the Fridge remove it to turn-off.
Check to see if your Power Center has a list of DC Fuse Circuits to confirm Fuse # to remove.
'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,180 -
I also have a 2019 Tab 400 with the Norcold fridge. It was not running consistently. I installed a new thermostat and it works perfectly now.I ordered the replacement from the RV Fridge Guys. https://rvfridgeguys.com/
Norcold Thermostat Control Assembly 635832 (NR740/ NR751) 635832 By the way, my 2 way fridge is wired into both the 12v system and the 120v system. -
The exact Month/Year nüCamp switched to only wiring the 12V side is unclear.
Most owner remarks suggest it may have occurred before year-2022 when it appeared in the updated Owners Manual.
I'll edit my earlier post in this thread.'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Well, I bought and installed a new thermostat control and when I turned the power on the fridge was running in the off 'zero' position again.
I turned the breaker off and it shut off for about 3 seconds then started running again with the breaker off!
I had to remove the fuse and turn the breaker off to get it to stop running!! Ugh.... -
To pull power from the frig you need to flip the 120V breaker, if on shore power, and the 12V fuse.On my 2019 400 there is a distinctive “click” when it switches to OFF. In the thermostat there is an internal rotary ramp that is engaged in the OFF position. I recall my thermostat had an issue with getting over the ramp to OFF and I replaced it.Rich2019 T@b 400
When you disconnect your thermostat (ie remove at least one of the leads), does your fridge stop?
if so, it points to a bad thermostat. If your fridge runs when the thermostat is disconnected, it could be a short in the wiring or a control board issue.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
