Equipment for repairing flat tire
kipwillkipwill Member Posts: 17
We have a 2018 NuCamp trailer pulled by a RAV4 Adventure, and would like to be better equipped to deal with a flat tire while traveling.
Do people recommend carrying just a pressurized can sealant, or a more expensive tire sealant kit, which combines a portable 12-volt air compressor and a replaceable container of sealant (such as the Consumer Reports recommended "airMan ResQ Pro +") ?
Will White
  • donmontalvodonmontalvo Member Posts: 182
    I patch my own tires using the usual flat kit from Amazon.
    https://a.co/d/4oPkrBw
    my tow vehicle has a dual motor compressor mounted under the front passenger seat…expensive, from my rock climbing days.
    https://a.co/d/4HBoBKM
  • MuttonChopsMuttonChops Member Posts: 1,881
    I'm of the keep it simple and 'for sure' mind set as my driving is mostly in the vast & empty western states.
    So I carry a TAB spare tire and socket/breaker bar for the TAB lug nuts.
    Get a replacement tire or flat fix at next large town.
    In decades of driving I've had at least five flats . . . only one (a slow leak) could be fixed with a plug or fancy seal can, all the others had such damage that a replacement tire was required.
    IMHO the likelihood that a seal can, etc will get you on the road again is low
  • Grumpy_GGrumpy_G Member Posts: 670
    Agree with @MuttonChops, a spare tire is the best option (between 3 T@b owners and myself we all have spare tires, were they not standard ???). In a modern car with TPMS you get an early warning, and in older cars you might notice it pulling to one side or similar. With a trailer it's either a bang or the fully deflated wheel rumbling around at which point the tire is ruined anyways.
    Just like @donmontalvo I carry a tire repair kit and an air compressor in my Jeep (standard equipment if you go off the beaten path), I only use the sealant stuff on my garden tractor ... :)
    edited August 30
    We carry a bottle and a scissors jack, lug wrench, spare tire, 12v compressor and a tire plug kit.
    California, USA
