Rust streak by door, under boondock handle.
RobermcmRobermcm Member Posts: 94
edited April 2024 in Tips & Tricks
Every time it rains, my 2023 tab 400 develops a rust streak down the left side of the door, under the boondock handle. Runs the entire distance to the bottom trim. I suspect it’s some poorly rustproofed piece of the sturdy boondock handle, but removing the bolts doesn’t loosen the handle. Suspect 3m two sided tape is in use.
Has anyone removed the handle and fixed this rust issue? Is it hard to get the handle separated from the tape? What was the cause of the rust?
interestingly, the Truma technician who recently worked on my 400 said that he is seeing that rust mark a lot. The mark comes off with paint polishing compound, but returns at next rain. It’s a pretty persistent mark.
thanks much.
2023 Tab 400
2015 Audi Q7 TDI
Northern Ohio
  • vttjvttj Member Posts: 21
    I am having same issue and was going to remove the boondock handle and use CNC evapo rust and repaint.  It seems that where the handle is welded and also the inside drilled holes are not properly coated.  Problem is same when remove screws it remains firmly stuck.  Trying to determine if it is double side tape and can I remove with out damaging the outside of the trailer?
